| Title | Size | Downloads |
| 08 Security Command Reference-book.pdf | 798.77 KB |
Preface
The H3C S5830V2 & S5820V2 documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C S5830V2 & S5820V2 Switch Series.
The Security Command Reference describes security configuration commands. It covers the commands for configuring identity authentication feature (AAA), secure management features (Public key management and SSH ), and attack protection features (IP source guard and ARP attack protection).
This preface includes:
· Audience
· About the H3C S5830V2 & S5820V2 documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5830V2 & S5820V2 series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
NOTE |
The H3C S5830V2&S5820V2 documentation set includes:
Category |
Documents |
Purposes |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Provides basic installation instructions. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
Fan assemblies installation manual |
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies. |
Power modules user manual |
Describes the appearance, specifications, and installation and removal of hot-swappable power modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
